Commander Fuel Pressure Sensor Q's
Hello to all,
I took my fuel sensor from the IP off today and all of the nuts, lock washers, and washers fell off. I tried guessing on putting them back on but I am not getting a reading of fuel pressure now. What order do these components screw on to the sending unit? Thank you.
And sorry if this seems like a dumb question.
![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
Hello to all,
i think i did washer, terminal, washer, lockwasher, nut.
does this seem right? if not i go outside and check. also make sure its grounded good.
dieselfan
sorry for taking so long, computer was down. i just went and looked, this is what i came up with, small locking washer,nut, terminal,washer(big),locking washer(big), nut. i couldnt tell if there was a washer in between, small locking washer and nut, there probably was if it came with two washers. if this dosent help, ill take it off tomrrow at work.
hope this helps, dieselfan
Lost Lake
03-18-2007 02:35 PM
rjm022
12-14-2006 05:20 AM
stock03
11-09-2006 11:27 PM
edtyler
10-12-2006 03:09 AM
