coil spacer?
Re:coil spacer?
I did the steel one on mine which is an '02, but I don't think the front suspension is any different on the 03 4x4's. I took the sway bar loose when I did mine and it went back together pretty easily. Had to take the factory jack and push the axle down a little to get the coil and spacer back in. It's a fairly easy procedure, but you'll need a good jack and some tall jackstands.
Re:coil spacer?
I would go with the steel spacers. I've read elsewhere that the plastic ones don't hold up well with the heavy diesel motors. I plan on installing a steel set myself, best price I've found to date is $129....have you found better?
Re:coil spacer?
found some on e-bay for 90 with 20 s&h. they are steel with a lifetime warrenty by BDS.
they have a 2" and a 3", what is needed ?
is the 3 too tall, *** low?
thanks for the info
gonzo
thanks for the info
gonzo
Re:coil spacer?
The 2 inch was perfect on my 2nd Gen. Made it exactly level. I haven't seen any new ones around here with a leveling kit installed, so I can't say for sure, but i've never seen a 3 inch kit for sale. All the leveling kits for the 2nd gen. are 2 inchers.
Re:coil spacer?
2" is perfect. I haven't seen a 3" kit. I went with Tuff Country steel spacers @ $129 from Suspensionconnection.com. Click below for a couple of pics. Mike
http://www.geocities.com/mike67rs/Dodge_Ram.html
Re:coil spacer?
Anyone have a link for some coil spacers that can be installed on a 4x2? I'd like to lift the front end of my truck up a couple of inches. It seems WAY too low. :
Re:coil spacer?
Hoss, since I've been in Aggieland (in physics class as we speak ), I have been told by several people that you can put a hockey puck or two on top of the front coil to help lift the front end up on a 2x4.
Re:coil spacer?
you know whats funny ive actually seen some moron do this to his truck........when he stopped the hockey pucks split and the front end of his truck was destroyed...... i was laughing so hard i ruined my boxers
