Codes
Codes
Hi all,
I hope someone can help me with the codes
I ran the codes on my truck and ended up with a few.
P PCU
P 1693
P done
P ECU
P 0216
Now the reason I am pulling codes is because on the long weekend I pulled my TT through the mountains and was getting dead pedal a bit. Only when I was cruising along with hardly no pressure on the go pedal or none at all ( down hill ), I would then either have to shift down and get the RPMs up or throw the tranny in Neutral and play with the pedal and it would come back to me. It would not do it if the truck was under load.
I just replaced the lift pump and fuel filter before I left because I was losing fuel pressure at idle and cruising with little or no pressure on the go pedal. My fuel pressure was consistant on the trip. 15-16 at idle and 11-12 wot. I run my Edge on level 2 when towing and level 1 around town empty.
The truck has 237,000 kms on it which is around 108,00 miles. When I did'nt have dead pedal the truck pulled hard and ran like a top.
Any help would be appreciated
Thanks
P PCU
P 1693
P done
P ECU
P 0216
Thanks
Dead pedal + 0216 = death is coming for your VP44
Clear the code and see if it comes back first. Might need a lp too if yours fp is dropping.
Now that the sane portion of my post is up there, the other option is to tap the wire, turn the j/a all the way up and see what happens If its dieing the box will kill it! Okay, maybe not
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
StormTrooper
03-28-2005 09:17 AM
