Coated exhaust manifold
[QUOTE=Timmay2]It does reduce surface temperatures of the parts coated. This is proven in many cases with infrared thermometers. A reduction in the surface temperature only means one thing, the heat is kept inside.
more heat = faster spoolup.
QUOTE]
Would that create higher egt's too?
QUOTE]
that website i put on here was wrong its http://cradin.com/ if anyone is interested.
I found these guys: http://clmcenterprises.srv08.yourhost.com/uper_hi.htm
The guy said 1 pt will be enough for the exhaust manifold and exhaust housing of the turbo. MUCH cheaper than sending it in.
I have a high temp powdercoat on my manifold. Looks real nice as far as I'm concerned thats all it does but I dont have dyno results or anything. I'd be careful with header wrap. Moisture likes to work its way inside and speed up rust and deterioration like crazy.
EdmontonCanada
02-26-2010 02:07 AM
kdbvulcan
01-27-2009 04:06 PM
jakeydiesel
03-30-2008 10:03 PM
gerry
10-20-2005 08:21 PM
