Clutches?
#62
If you have an HO, then you should be within the FEs holding range, twins or not-- unless you've swapped the VP for something hotter.
jmo
#63
I put a Valair Full Feramic 13.25 0n my 2002 last month. It's got about 700 miles on it now. Its grabby for shure, but holds on for dear life! It's really only grabby on 2nd gear launches though. If you get the RPM up a couple hundred revs before letting the clutch out it'll pull away cleanly in second.
It held last night on my way home from work. I raced a F150 Harley Davidson edition with the lightning motor. (one of my co workers) From 35mph till we started backin off at about 70 we were dead even. I was in 4th the whole time
#64
The good thing about buying a SB is that you get customer service for life.
At the end of the sled pulling season my 3850 12cb is getting upgraded to a 4200 iron giant and I know Peter will hook me up like he has done in the past.
#67
The 2003 Lightning/Harley Davidson had about 340hp stock, his is no longer stock though. I know he at least has a chip in it. I should be around 400 myself but I have waaay more torque as we all know.
Jason
#68
Lightnings can pull pretty hard, but when they start going to undersized blower pulleys they tend to start puking trannies
I wish my truck pulled hard enough to take a Lightning. Maybe from a 50mph roll if I already had boost on tap.
jh
jh
#70
I went to the local 1/8 mile track before I put in the 370s and still had the 35/40 hybrid and got stomped by a 4 door lighting with 4 people riding in it. I ran a 10.03 and he ran a 9.2 I think. It was in the low 9s.
