clutch problems
Old 11-02-2008 | 12:27 PM
Tingram's Avatar
clutch problems
my clutch on my truck has been having an issue were sometimes it wont disengage all of the way. sometimes it does it and sometimes it doesnt, but it is getting worse. when you pull up to a stop light or something and push in on the clutch it will keep trying to pull not reall hard but you can feel the truck trying to move. then if you stop and go to put it in reverse you cant get it in reverse. i think that it is the slave cylinder but not sure some guys are telling me that it is the clutch fork. i havent had to put any oil in the master cylinder so i dont think that it is the master cylinder.
Old 11-02-2008 | 12:31 PM
98.5Hotrod's Avatar
What kind of clutch, how many miles on it.
Old 11-02-2008 | 01:21 PM
Tingram's Avatar
its a south bend ofe clutch has about 60000 miles on it. no towing only driving and it really hasnt been run to extremely hard.
Old 11-02-2008 | 01:45 PM
torquefan's Avatar
It's also quite possible that you have a seized pilot bearing, and it is keeping the transmission's input shaft spinning even after the clutch is disengaged.
DJ Turbo.
10-13-2011 10:11 PM
Fishbait
06-06-2006 01:34 PM
mbmrang
01-21-2006 01:49 PM
kwhite4
05-09-2005 04:22 PM
