Chip/Programmer suggestions
Truck in sig in question, going to keep this thing for awhile, so I want to do somethings to it. Truck is stock, except for tire size. Will be adding an aftermarket exhaust, 4", turbo back, to help it breath. I'm wanting gauges to keep track of everything, but by the time I buy the gauges, I'm at the price of most programmers. It's a daily driver, not a hotrod. Pulls occasionally, 99% of the time it's less than 10k. With 244,000 on the tranny, I'm worried about it. What are your suggestions? I was leaning towards the Edge w/ attitude until I read some stuff on here about it damaging computers. Let me know which way to go. Thanks.
I have not had a problem with my edge at all. the only bad thing wasi had to rebuild my tranny. couldn't handle it.if i was going to do it again i would go with the quadzilla. i like the app for the ipod tuch or i phone.
you may know this but just saying,
if you add a box, and it is tapping the vp-44 you should really upgrade your fuel system if you haven't if you have the oem fuel pump upgrading to a bigger fuel line possible a fass, airdog, raptor etc, will allow full fueling and and better fuel pressure to your vp and not have fuel starvation due to the higher levels with the fuel boxes. can you get away with it for awhile on the lower settings yes. I believe the only problem that adrenaline was having in the past was a fuel pressure sender? not sure what the fix was current.. Edge has alot of safe settings to use and alot of other stuff. I bought the tst and smarty in the past love it. I may have looked at the edge then if it was out at the time. good luck
I've never heard anything about edge boxes causing ECM problems. I've had my Juice W/Attitude for a few years now with no problems, very happy with it. Not only does it give you guages it gives you the ability to set audio alarms based on your parameters.
same here, no idea where these rumurs of boxes hurting ECM. the box modifies the signal after it leaves the ecm, so its near impossible for it to cause issues, a programmer on the other hand is a totally different issue, as they are known to cause ecm problems during re-programming
my edge has at least 4000HOURS of trouble free use, and would by another in a heatbeat
DodgeDawg2500
11-23-2011 08:53 PM
WEATHERBY460
07-11-2006 07:01 PM
imfletcher
15
05-12-2006 08:31 AM
G-NOTE
13
08-16-2005 02:03 PM
Big Smoky
03-15-2005 06:15 PM
