Chip
Chip
Can someone recomend an add-on chip for me?
I am still transporting RVs throughout the country. I try to pick out the lightest units to haul, typically under 10,000 lbs. I always ease off on the pedal and manually shift when I need to go from OD to third. I haul in 3rd only if the unit is really heavy or I have a head-wind condition.
I try to baby this machine to make it last as long a possible and I am especially kindly to the tranny. However, after over 230,000 on the truck I would like to try a little more power.
What chip or chips should I consider and where to buy them?
Also, when the tranny goes, what should I replace it with? Same with the next fuel injector pump.
Thanks in advance.
Tim
Thanks in advance.
Tim
This topic is like a cocked gun! There are several good boxes. From what I've heard the Edge EZ is a good towing box I've never used it though. I use a TST Power Max 3 w/ remote it works well on 5,6,7 hauling.
Tim
Edge EZ or something comparable!
Check Classified...(Top of this Page)....under 2nd Gen - Accessories. Good price on EZ but will need an adaptor for 2002. Better price on a Diesel Dynamics box (EZ model), made by EDGE. It's for a 98.5 CTD and may not work in yours?
If not familiar with EDGE, check here... http://www.edgeproductsinc.com/dodge.html
For trans upgrade....I love my DTT and recommend them highly.
Check here http://www.dieseltrans.com/
I would recommend you do a tranny search...check all the top brands and start learning now...lots to read and you'll be ready when the time comes. JMO. Took me 2 months of off & on research to be comfortable with my decision.
RJ
RJ
I recommend the same thing as RJ, just do some research. I would say get an EZ and you will notice a big difference than compared to stock. It just depends on what else you plan on doing to your rig later on down the road. With the EZ, you shouldn't have to worry about your tranny. But to be safe, get some gauges first (pyro, fp, and tranny temp).
where to buy
Kyle:
Where can I buy an EZ and what can I expect to pay?
Thanks.
Tim
Thanks.
Tim
Originally posted by Kyle Graham
The ez will give you 65hp and 185lbs/ft of torque and is a safe modification for you drivetrain
Like RJ said, check the classifieds....seems like the EZ's are always in there. If not, go to the links page and search (call places) for the best price.
I would also recommend you get a fuel pressure gauge. Before I installed mine a couple weeks ago, I "thought" the truck was fine. Turns out it most likely saved me from having to see a VP44 sitting under the x-mas tree
Originally posted by dodgediesel4x4
I But to be safe, get some gauges first (pyro, fp, and tranny temp).
Edge Products' EZ is a great upgrade, but I do not have a base of comparison as it is the only add-on box I have used. I actually had a Edge Comp, more power, but used it as an EZ, wire untapped, for a little while.
Also, when I added this box I had a strong clutch to withstand the extra power. Look into tranny upgrades through searches on this website and members' signatures.
Online store, online classifieds, and sponsored advertisers are good place to find one. As well as ebay, search engines, etc.
Good luck, Pat
gergthegreat
12-30-2008 09:19 PM
bansh-eman
01-27-2008 02:48 AM
Elk_Hunter
10-24-2006 03:17 PM
