Check engine light and other problems..EDGE
Hey, a little help here, had EDGE installed on my 2000 Dodge w/Cummins. After in about 200 miles now check engine light on and rpm guage has stopped working also sometimes the engine surges a little like it is having problems getting fuel. Ideas? Thanks
Don't screw around with opinions and hear-say on the internet, call Edge tech support and have them step you through some trouble shooting. They are ultimatley the ones that will fix what ever is wrong if you have module problems. Try unplugging the module and see if the same thing still exists, it may not be the Edge product. Just trying to help. And post your products so we know what we are talking about so we can help you better if we can.
I have the Edge w/Attitude so yes have fuel psi guage, every now and then if I really get on it at the highest setting I will get a low fuel pressure alert, but normal driving the lowest i've seen it go it 8psi. new fuel pump? suggestions for a high performance /reliable one?
What was asked is what module you have. Edge is a company, not a model name. They make three different boxes for you truck. The EZ, Comp, and Juice.
I say you have a crank sensor problem, seems that is sometimes the case when the tack quits working.
Well, the winner is !!!!! code p0336 "crankshaft position out of range" had the crankshaft position sensor replaced. 54$ labor 197$ for the sensor, fixed the problem. Thanks for the help fellas. Steve
madbomber
11-15-2004 05:07 AM
Fillerupsonny
10-09-2002 06:01 PM
