Cheap Upgrades or Tricks???
Re: Cheap Upgrades or Tricks???
Originally posted by G-NOTE
Does anyone know of any other cheap or free upgrades for an 01-02 24 valve cummins, besides a air filter and stright pipes....
You gotta pull the hose off the front of the turbo. The silencer ring is held on with a small snap ring. Kinda a pain to get out but not to difficult. As far as injectors, many sources. Click on the links up top we have a bunch of sponsors that sell them. I got mine of off Ebay however, and I still have my old injectors to use as a core if need be when I step up to some to bigger sticks (injectors).
look at the turbo....you will see a snap ring, and a tapered ring leading into the compressor. Pull out the snap ring(prepare for some nasty word...it can be touchy) and then pull out the tapered ring.
OK Guys but how???
I've have removed the airbox, and I looking @ the front of the motor...What do I do next???
OK Guys but how???
Pull the intake hose off the turbo.
You'll see a snap ring holding the larger "ring". I used a combination of thin flat blade screwdrivers to pry the ring up out of the groove. Once the end of the ring is out you can grab it with needle nose plyers and take it out. Once the snap ring is out the silencer ring will come out too. I did make some metal shavings and vacuumed those out with the shop vac. Shavings are very bad for the turbo and motor
Originally posted by SilverRam01
Those of you putting bigger injectors in.....do you see a noticeable difference in mpg's ? I'm getting 18 mpg out of my stock truck at the moment.. I'd hate to lose that.
DD2s gave me 19-20.5 hwy
Mach4s gave me 20-23hwy.
jlh
Yeah but be careful with your airbox in the process of removing the silencer ring...I popped mine loose...x.x so now I am using it as an excuse to get a Scotty Air II, and I really dont think the turbo is that much loud, at least to an Unbearable point. I really enjoy the lil whistle!
