Cheap track bar solution?
Old 08-20-2004 | 02:32 PM
fourwhls00's Avatar
I have been doing some research on our track bar issue.
I looked into the new solid steel bracket that allows for use of the 03 track bar. It sounds good, but that a lot of money all together. 129 + shipping for the bracket and ~185 for the 03 track bar. Your looking at 300+ before your done.
I then looked into the Moog track bar. I read the article on the federal mogul website reguarding their acclaimed fix by using bigger sockets.
http://www.federal-mogul.com/fmeconn...loads/2285.pdf
This sounded pretty good, so I started searching for prices. I can find it for around 230. Moog's part number is DS-1413.
I then went to advanceautoparts.com and plugged in this number to see if I could by it locally. I was shocked by the results. There are two other companies making or selling this track bar using the same part number. The shocker was the variation in prices.
Moog $234.99
TRW $100.73
Mcquay Norris $139.99
The question is: are they all the same part sold by different vendors or are they mimicing Dodge's part number?
100 bucks sounds great, but am I getting something that will help with the issue or just a temporary fix?
Old 08-20-2004 | 05:14 PM
KatDiesel's Avatar
Moog will still wear out. Cheapest fix is a "Lukes Link" on your current factory bar.........$63.
Old 08-20-2004 | 09:23 PM
diesel_kid's Avatar
The Lukes Link to me is just a bandaid fix, it covers up the problem, instead of fixing it. I would spend the cash and get the 03 Track Bar Upgrade, Or the DTprofab Adjustable Trac Bar. JMHO. Thanks
-Jared
Old 08-21-2004 | 02:51 PM
P.O.R.'s Avatar
i went through 3 moogs in 3 years,now i have DTB kit,now the truck handles great-like it should..
Old 08-22-2004 | 12:07 AM
jimk's Avatar
track bar
What is a DTB kit an is it the best one to buy. I have the brace that goes to the steering box but it still needs the track bar thanks Jim
Old 08-22-2004 | 08:34 AM
P.O.R.'s Avatar
it's a bracket that let's you install a 03 track bar,witch has no tie rod end it uses bushings on both ends,you can see it hear....www.solidsteel.biz...:)
Old 08-22-2004 | 08:35 AM
P.O.R.'s Avatar
oops try this..
www.solidsteel.biz
Old 08-22-2004 | 09:33 AM
CO Lineman's Avatar
My dad put one of those things on his 01 dodge from solid steel and says it improved steering a lot....
CTD2001
08-22-2009 11:03 PM
Common
06-01-2008 07:15 AM
Dinner
05-29-2007 03:02 PM
kwillis-a
01-25-2007 10:10 PM
Strjock81
01-13-2005 10:16 AM
