Cheap 24 Valve Performance Injectors
I have a 2000 dodge 24 valve and i found some very cheap performance injectors. The company is diesel care and performance and they claim their injectors are 275 horsepower and only 40 dollors per injector.Almost to good to be true.I want to know if anbody has heard of the company or has the injectors in there truck please let me know.
The Guru
I just gave away a set of 100rwhp injectors. Does that qualify as the cheapest set. I need a set of cores and I don't want to give away a decent set. The guys was pretty happy..
From what I have seen first hand... as opposed to just heard or read.... we still get what we pay for, when it comes to injectors.
One very active member here bgt. an inexpensive set of "100 HP injectors" and gained less than 30 HP over his previous 275's. He is knowledgable and was not surprised, but others might be disappointed with "bargains".
RJ
RJ
RJ
RJ
The 275's, would have put him at 220rwhp.
That's only a 32 HP gain going from a "275" injector, to a "100 Horse" injector, and depending on what other upgrades he had, it doesn't sound like he was ripped off much at all.
However,
You get what you pay for.
Search up for Mach 1 injectors by F1 Diesel, and then search for BD injectors. BD's injectors, although living up near to the HP rating, are so smokey, you wouldn't believe, however, F1 injectors are very clean for the HP rating.
An 80HP BD injector will smoke like one of F1's 180HP injectors...
My $.02
Merrick
The Guru
I can say that my old BD XXX 90's where quite smokey. They smoke almost as much as my current mach 6'ers. I couldn't run the BD 90's with twins, tons of smoke and no power. Not a good combo. The truck that I put the 90's into actually impressed me. The HX spool-up was quite fast. I could pull 30 lbs in less in a couple seconds from no boost. The truck was a 01, five speed and had an edge ez box. Man the rockers where out a long way for a truck only having 100000 miles on her. I could have fit typically 25-30 thou under the exhaust and about 12-15 under the intake. He might have got one of those soft Brazilian cummins cams. It ran pretty quiet after the rocker adjustment.
ddestruel
11-13-2007 04:59 PM
