Changing From A HRVP 44 To A SO VP44 = Help???
Changing From A HRVP 44 To A SO VP44???
Anyone out there know the pump number on a SO VP44. I'm trying to find a SO and when they ask me for my engine serial number, it shows up as a HO because it is an HO. They have a hard time selling a SO pump to a HO motor and don't believe the SO will work on a HO motor??? (that's too many SO's & HO's) For now I'm hopefully(if Qzilla will let me) going to try a new Quad Race Box to see if it will fix the idle lope on my HRVP 44 and if that does then I won't have to spend the $1500.00 on a SO pump...
Why not go through the states? $450 difference is significant, especially at today's exhange. I was gonna go look at my engine serial number so you could give them that, but I forgot the tag is at home.
I was just curious for now for a back up plan. I'm hopefully going to try the new Quad Race Box and if that will cures the horrible Idle, then I'm set...
My idle is getting worse and worse every day. I'm starting to think my VP44 is on the way out??? Tried Smarty SW#1 and it smoothed it out for a little while and then back to a horrible idle. Just getting tired of the people looking at my truck and thinking, "what's wrong with that heap???" No codes but that doesn't mean a thing...
You tried different lines and connector tubes? When I went to the .120 connector tubes and .093 lines I had no rough idle. went down to .084 lines and very slightly noticed it but almost anyone thought it was jsut a normal diesel truck idle.
jefe4x4
01-24-2006 07:47 AM
