Centramatics
Centramatics
I just ordered a set for my truck. Anybody use them? If they balance out as well as advertised, it's well worth the money. I just paid 97.00 for mount and bal on the wifes truck with 36's!!!
I could reduce that to about 20.00 if I don't need a balance. And they stay around forever, I woun't lose the balance, and I can keep them if i sold the truck (which I'll never do).
What ya guys think?
www.centramatic.com
What ya guys think?
www.centramatic.com
I've used Centramatics in the past but http://www.counteractbalancing.com/ do just as well for $6/tire
I do run the Centramatics and yes they work. I how ever did not remove the weights from my tires, that part of it just does not make sense to me. I have found them to be great on the highway, there is absolutely no vibration either in the steering wheel or seat. I run 255-85-16's and it is pretty normal to have to add 2,3 maybe 4 onces of weight to get them balanced. I have a set of BFG M/T's and they were all in the 2-3 oz range. I also have a set of Trxus M/T's and they were ALl 2-3 also with one at 5 oz. With your larger 36" tires I would think 5-7 ounces would be the standard? I don't see how it would help to not have the tires balanced, there is enough weight to smooth out several onces of out-of-balance, but I do not think there would be enough to do it by it's self. I may be wrong, but they were not that heave. Any way good luck and let everyone know how they worked, I hope you are as pleased as I am.
Well, I tried them and now I have to send them back cause they didn't work for me. I had a new set of tires put on my truck and told the tire shop not to balance cause the centramatics are supposed to do the job up to like 12oz of correction. I know that my tires aren't that bad. I drove them home with the old weights on (the tire shop didn't remove them) and was surprised at how much they did not shake. Just a little bit at higher speeds (60+). The balancers didn't help at all so I went back home and pulled the weights off the wheels and still, they did not help. I am running a large tire that roads well and usually doesn't take much weight to balance.
the good news is that when I called them, no hassle on the return. I think I'll end up eating some shipping but I guess it was worth it to find out. I'd be mad if I had spent $50+ to have them balanced in the first place, removed the weights and had to re-balance now.
It is a shame they didn't work for you, but at least now you know. I love them, they are very smooth. I did not do as they suggested, I had my tires balanced and then add the centramatics. What they wanted did not make sense to me, I just figured they were trying to sell more by people thinking they would save money on balancing? Any how I like them, and would not recommend to anyone, THAT THEY BUY THEM THINKING THEY WILL NOT NEED TO BALANCE THERE TIRES.
BigBlueDodge
18
07-02-2007 11:17 AM
lwcmattlifter
04-16-2007 05:33 PM
BigBlueDodge
10-01-2005 07:55 PM
