catcher ecm and comp
if i put in a normal catcher ecm that has timing added can i use it with my comp or do i run the risk of engine damage due to the added timing
edit: does the catcher ECM remove the 2700rpm defuel like the smarty does?
Yep, Marco, "used" to make a special catcher with no timing so those with a comp could run the catcher. That is why he has both timing and no timing settings on the smarty. I've heard of those who tried timing on the Smarty with the comp and didn't notice any difference. I decided to try and didn't really notice any difference either. I did not leave it that way for long though, I was afraid it would cause an issue.
luckily i will have a smarty for my use on the dyno. 2 runs with the comp and the 3rd run with the smarty on level 8 (no timing) since i am currently saving the cash i need for a smarty. cant wait
The Smarty is not going to do much on the dyno. It will give a steeper curve for HP & tq when they first come in cause ...... that's what Smarty does!
I would not expect max HP/Tq #'s to be very different from your Comp.
RJ
RJ
I think RJ is right. I don't think it'll help much on the dyno. Dyno is for max power, and at some point your turbo is going to light regardless of being laggy and reach max power and tq for the dyno to read. The good thing is the Smarty is a quick load and unload. Try it both ways and see what the results are with and without. Keep us posted as to the results.
Originally Posted by getblown5.9
ill have my own soon hopefully...but borrowing one this saturday will work for now!
Originally Posted by Bob Wagner
are you still running the beta box the tim had? I need to keep track of these beta boxes.
Thanks
Thanks
im confused is this directed at me or someone else in the thread...becuase i have no idea what you are talking about so i will assume this is for someone else,
tim...thats my name
