cat turbochargers
cat turbochargers
i have a couple of turbochargers from a 3126 c7 cat with a front compressor wheel measuring 62mm and another being 64 and another being 66mm. would these work like a htt turbocharger they look really close alike. and they are wastegated and have a 4" exhaust and from what i could figure out they have a 14 cm exhaust and a 65mm turbine wheel. is their anybody that could help, if so please do.
When you find out if they work, sell one to me! I think they do not have a divided housing though, which would create pulses of exhaust flowing back into the other three cylinders' exhaust manifold. But might work, maybe someone has already experimented. Do they need a water hook up as well, or just oil?
kinda off the subject but how do you like your twin set up on the 99. i just put the htt ss on my 97 and was thinking about doing twins sometime. did you fab your own plumbing?
It might hurt spoolup a tad but that's about it. Many 4-6cyl turbo applications don't use split turbine housings.
I have been told they have a 71 turbine wheel.
Have you got a way to find out?
Yes, they should work although it probably won't have the popular hx-40 flange for the downpipe.
ya what turbo do you have crab, there is a big rig yard around the corner and i can get tons of turbochargers for like 250 bucks just the nice ones are like 450 -700 thats what i paid for the c7 chargers but they are nice.
It is just that I do gaze longingly every once in a while at one we have around here. It is on a 600 ci Cat that powers a fire pump. The turbine casing and the exhaust manifolds are both water coolded.
Jim
oh no this turbo is for a 3508, brand new, like $2,500. marine app.
you know the is a destroyed generator was in a wreck when being moved that has a monster turbo on it. crab let me go grab this one and cross check the a/r with yours
