Cant start truck after installing FASS - HELP!
installed pump line directly to stock filter. Only problem I had was getting the new fuel connection at the tank to fit. Gave up and just used a hose clamp. I cycled the pump (it ran for about 20 seconds every time) probably 30 times and it wouldnt start. I then discovered the clamp wasnt tight enough at the tank connection and it was leaking. Really tightened up the sucker. I did disconnect the fuel line to the VP to move the filter during the install, so I knew I had to bleed air. I have my fuel pressure gauge line hooked up to the shrader on the VP, so I have kept the connection to the sender unit cracked to bleed air. I can get fuel out of the line, but the thing just wont start!! I have bumped the starter at least another 30 times! HELP.....ANYONE!
Where are you gettin fuel out of? When you redo a fuel system to start it you first crack line at the vp bump starter till you get fuel outcoming out. You have to tughten the line up while pumps runin. Then if it dont start you need a buddy to crank the motor over while you loosin the nuts on 2 injector lines. I always loosened 3and 5 at the head.
Got the sucker finally running. I was getting decent fuel from the fuel pressure gauge line tapped to the VP44. Bet I must have bumped that starter 75 times! Still getting a few drips though from the darn connection at the tank line. Just doesent make any sense, I have really tightened the hose clamp I used instead of the piece that came with the kit that I couldnt get to go back on.
Are you talking about the quick connector at the tank?? if you did not use the metal quick connect.. and just removed the old connector, and slid the hose over the tubing where the connector should have gone... this works most of the time.. but sometimes the plastic where the connector will crack if clamped to tight... If so.. you might have drop the tank, and make a new fuel pickup line...
Good Luck,
Bryan
Good Luck,
Bryan
Good Luck,
Bryan
Good Luck,
Bryan
Originally Posted by lezmark7
Yup, the quick connent wasnt so quick, could not get the sucker on and the more I looked at it, the more comfortable I felt with a hose clamp. I was thinking of wrapping a little tephlon tape around the plastic line since the hose did slip kinda easily over it... now you have me worried I may have broke something..
dodgediesel
17
11-07-2008 11:15 PM
