Canadian suppliers for 5" exhaust?
Old 03-24-2005 | 12:56 PM
CTD NUT's Avatar
Does anybody know of any Canadian suppliers for 5" exhaust?.....I have not come across any.....also, will they sell a 5" system minus the down pipe?.....I'm trying to source out all my parts needed to build some twins so I will have to make my own down pipe.....I'm going to start with the stock 12cm HX35 on top for now and a stock 26cm Schwitzer HT3B for the bottom.....is anybody running home built twins without blow off valves?......Is there a need to wastegate the top turbo or do you just gate the big turbo?
Old 03-24-2005 | 11:24 PM
Beast2B's Avatar
how about www.piersdiesel.com or www.bd-power.com ?
Most twin set ups run a wastegated top charger or an external Wg for the top charger. Either one should feed the bypass into the hot pipe BEFORE the bottom charger to allow that bypassed exhaust to light up the bigger turbo. No blow off valves that I can remember seeing on the diesel set ups.
The high end of the efficiency range for the HX35 is ~35lbs boost. Depending on what is done to your head and head gasket, you may want to limit overall boost to accomodate those mods.
PEAKSTRYDE
10-11-2007 05:20 PM
berner
35
02-23-2005 12:28 PM
Toby
06-25-2004 10:31 PM
FARGO
05-26-2004 05:26 PM
moopa
02-26-2004 01:07 AM
