can you stack chips
Old 08-08-2008 | 12:01 PM
91.5 beater's Avatar
can you stack chips
Can you hook up two chips at the same time and stack them
Old 08-08-2008 | 12:16 PM
j-fox's Avatar
Pringles stack the best.
If by any chance you are asking about 'boxes' or 'modules', some you can some you can't. Depends on what you are stacking, timing or fueling?
Old 08-08-2008 | 12:54 PM
dzlfarmboy's Avatar
Yes what two products are you refering to?
Old 08-08-2008 | 03:14 PM
I have a power puck what chip can i stack it with
Old 08-08-2008 | 04:23 PM
AggieJustin's Avatar
The puck is a timing and fueling box similar to a Edge EZ or Van Aaken. You can stack a TST with it to tap the wire to provide additional fueling.
Old 08-13-2008 | 04:44 AM
dsl kicks gas's Avatar
i ran one with my tst.....
also smarty tst power puck stack......way to much timing would NOT recomend it
i ran the smarty and puck together and actuley had more power with out the puck
a set of injectors would work well also
Old 08-13-2008 | 08:00 AM
dzlfarmboy's Avatar
If anything a TST would benifit the most. OR just go with a Drag Comp or Adreneline by themselves.
Brett
Old 08-13-2008 | 09:47 AM
Mike Holmen's Avatar
The Guru
Redline box with the smarty stack. Use the edge drag fuel pump wire is the big power for VP trucks. Your VP might not like it, but they make more VP's. The red box will allow you to rev to 4k, so the valves might float as they are only good to 3400 rpm so heavier valve springs is a good idea. Happy stacking. I just use the drag box and smarty. Its enough for me.
Totallyrad
07-19-2011 08:41 AM
Smokin98.5
04-09-2008 03:21 PM
TexMexCowboy
08-01-2007 11:06 PM
Juiced01z06
18
02-14-2007 12:46 AM
Jvenne86
01-27-2007 12:03 AM
Quick Reply: can you stack chips
