can someone ppost close up pics of Twin installs
AS topic says I have a used set of twins which I would like to get on my truck it didn't come with any detailed instructions, so could someone set me in the right direction thanks in advance
Who's twin kit? BD has some instruction that might help though.
http://www.dieselperformance.com/pro...2002_24V)1.pdf
like he said, not sure what kit you have or what part you have but heres mine......
hardline coolant pipe must be removed and line rerouted. turbo drain will have to be adjusted or cut rewelded to compensate for new turbo height. both oil feeds will come off the top of the oil filter head 1/8" NPT ports. 2nd oil return will go in the block casting boss with the cup plug in it. you can see it in this pic bottom rearward of the block.
I found install the manifold to head 1st, then lay the primary down on the framerail. install secondary to manifold with hotpipe already attached. then get a helper to get under the truck and push up on the heavy **** primary while you put the gasket and bolt it to the hot pipe.
thanks for the replies I have a set of Holsets not sure if it is a kit you can buy or someone pieced together it is 99% complete just need a drain line back to the block as far as I can tell. My truck is an 01.5 but should be basically the same Idea I heard something about turning the exhaust mani upside down? for a better fit or something,
OK so now that I have directions, and all the parts (i believe) what kinda of Trany upgrades have been proven to hold up and about how much will that run? thanks I am looking for around 500h.p. give or take, whatever keeps the headgasket in place
JJK98CTD
02-02-2009 05:37 PM
HOHN
23
12-13-2004 10:33 AM
