Can A Silver Bullet????
Can a silver bullet support mach 7's or do you think that it will be to hot, going to run a helix 2 and will run water/meth if you think its to hot. High altitude 6600ft, dont tow very often.
It will a little toasty cruisin around on hills and such, esp at that level. But wot it will cool it enough. Your problem will definately be your H.O. vp44. Wont get the full benifit of that big of a stick. You will need an S.O. vp to use the power.
I've ran the 7's with a pro street 66 and it would never clear the smoke up. IMO, 7's should only be ran with twins or nitrous. I actually gained 13hp going down one size and smoke clears to very light haze.
i know a guy who runs mach 8's, TST comp, silver bullet, nitrous and water meth. with both spraying it will clear the smoke, but im sure without it the smoke wont clear. i dont know how his EGT's are tho.
btw he made 785hp with that combo
What kind of power did you make with your pro street and 7's?, i got a pro street coming this week
Hey Steve, I dont know, I believe their real similar between the exhaust wheel and size and Morrison seem to do well with his and the price difference was a good bit,and have talked to some people that have tried both and they didn't seem to much difference in them. ???? I dont know we"ll find out it guess, im gonna try the smarty/tst and wanna come up to kauffmans and dyno this spring. We'll have to take some test rides!
I run the silver bullet and Mach 7's and have a H.O. I was possed to dyno Monday but tore the rearend out, so i must have a little power. but iwas gonna dyno with the H.o the switch to my S.O pum and see the difference.
texhand
02-09-2008 07:56 AM
Syndicate
13
06-25-2006 11:57 PM
Rollincoal
04-14-2006 11:22 AM
