Can a performance box cause damage to the VP44??
Man you guys can scare a new owner! I am looking to install an edge box on my 01 for a bit more pull on the hills, but you got me very nervous. Is it not a wise move? the truck has 203k miles on it. Just replaced the lower fuel pump a month ago. I dont want to set myself up for another stranded week-end.
dont run ATF ive heard, something about the detergents will clean the pump and cause failure......but that said at work we have ISB's with 5k+ hrs on them with atf added to every tank and the fliters filled with atf
ive been runnin ashelss super tech 2 cycle oil at around 100:1 ratio(give or take) i know it quiets the p-pump down in the ol 12v...
also heard about running used motor oil, maby in the old mech pumps but i would stay away from it in the vp
Registered
Dont know if its any better - but if you get a VP-44 from Rip Rook at www.sourceautomotive.biz he WILL warranty them WITH a pierced wire. Dont bother with the dealer.
okay what i was told by boosting the pressure in the fuel lines going to the injectors and not having bigger injectors it can hurt your pump so with that being said it has no where to go but back into the pump. So pick your poison. Trust me i know and the wire was not tapped on my pump and they will on warranty the pump after three week and about 1000 mile it locked up so it is your call.
I think you have to let him know when you buy it - make sure you mention it.
http://www.sourceautomotive.biz/inde...d=75&Itemid=25
BTW, do you have fuel pressure and EGT gauges?
-P
