can the lead for the pyro be shorter???
on the isspro pyro guage there is a lot of extra lead there, can I wack off a couple of feet wo changing the reading???
Re:can the lead for the pyro be shorter???
The experts wil probably chime in soon but from my experience leads on things like pyros are calibrated and if you shorten the lead it will cause erroneous readings. Don't know on the Isspro pyro.
If it were my gauge I would NOT shorten the lead.
BTW, how is your truck running now? Are you
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Hi mexstan and all
its got about a 100 miles on it,,as you see puting guages in. so far so goooood on the runnning part. 8)
It should be calibrated for a wire that length so don't cut it.
Also be sure to route it away from any wires that can cause some noise transmission.
I know how to recalibrate for shortening wires but it takes some test equipment most don't have. In a nut shell you add resistance via a potentiometer or set of fixed resistors to make up for the wire you cut out.
So don't cut it.
So don't cut it.
streetsmoker
09-20-2006 02:07 AM
unioncreek
06-23-2005 09:19 AM
royta
27
03-22-2005 03:01 PM
