Can I hook up 3 "lights only" to the H/L switch?
..ok I've been working on installing my 3 gauges off and on for more than a week...question: can I hook up my 3 lights only gauges to the one wire on the headlamp switch, so I can dim them? Or is this too much current to draw from..I will use an after market fuse panel for the + pos source to run the gauges..Where did you tap in for the power with key on ....thanks in advance..
Yes, but it can draw a lot of juice and cause problems with an already hot-running switch.
If you have gauges that use newer lighting technology (like the indiglo typle lighting or LEDs) then it's perfectly safe. With regular incandescent bulbs, it's ALMOST perfectly safe...
Have fun!
Have fun!
..that wire in the h/l switch does look like a small gauge wire..maybe I'll go oover to the ash tray light wire..here is the link about that wiring..thanks
https://www.dieseltruckresource.com/...ight=wcbcruzer
withalligators
10-08-2014 11:22 PM
Totallyrad
07-19-2011 08:41 AM
Banzai Bob
02-24-2010 01:24 AM
PEAKSTRYDE
10-11-2007 05:20 PM
Joe T
05-31-2007 03:05 PM
