can i CHEAPLY recalibrate speedo and OD shift speed (do it myself) ?
Is there a CHEAP programmer I can buy (and learn how to use) that will allow me to recalibrate my speedo for larger tires, and also change where auto trans shifts into OD (change from about 45 to 55). I don't need/want performance, etc, etc. How much money would I have to spend to do this myself ?
Thanks, doug
Thanks, doug
Thanks, doug
Thanks, doug
I don't believe there is 1 box that will do both functions.
Smarty or Superchips (former preferred) will do speedo recalibration in addition to some engine performance enhancing.
Some off-the-shelf DRBII code readers will also reprogram the speedometer (I think?), but they aren't really cheap either, and often don't communicate well with our dual computer vehicles (ECM and PCM).
Most of the aftermarket auto transmission rebuilders have a box that will let you set the shif points,
or you could find an Emjay Strategy Programmer (I think thats the name), but you'll only find it on Ebay or Classifieds, as the inventor passed on and the family stopped making them.
phox
Originally Posted by Abbynormal
I'd like to know the same thing for a '96 model.
Does the 96 have the 47RE or 47RH?
phox
He has a gasser truck.
Anyway, like the others said, you can't program the tranny w/ a programmer on the dodges like you can some other makes.
I had a hypertech on my '01 1500 gasser and it let me change the speedo for tire size, but no tranny options.
Originally Posted by phox_mulder
or you could find an Emjay Strategy Programmer (I think thats the name), but you'll only find it on Ebay or Classifieds, as the inventor passed on and the family stopped making them. phox
Strategy(tm) Lock-n-Launch(tm) Controller
from Emjay Engineering LLC
The Emjay Engineering Strategy(TM) Transmission Controller for Dodge RAM Cummins TD Pickup has a new option called Lock-n-Launch(TM). Lock-n-Launch locks the torque converter clutch at full throttle for manual-trans like launch off the line, maximizing low-end torque transfer to the wheels. The controller still has all of the standard Strategy features, including TCC control, Shift Curve Control (Patent Pending), Exhaust Brake Control, Overdrive Lockout, and to top it off, three profiles selectable on the fly with an in-cab switch! Now you can have optimized profiles for street performance, towing, sled pulling, racing, or whatever with the flick of a switch! No other controller even comes close to the quality and features of the Strategy controller.
SKU / Part Number: EMJ-1LE (no longer offered)
Compatibility Notes: All 1996-present Dodge RAM Cummins Turbo Diesel Pickups with 47RE or 48RE automatic transmission
arcojet
02-20-2006 10:05 PM
edge600
02-19-2006 06:39 PM
Batts
08-06-2004 12:59 PM
