Cam install
the lifters are super hard and don't wear as fast as they do in a gas motor, make your self a set of 1/2" wood dowel rods and rubber bands to hold the lifters up when you pull out the old shaft and slide in the new one. you can check out how to do this in detail on this site some were I am sure.
TRE diesel performance has a killer deal on the Helix 2 cam right now.
The lifters come out thru the camshaft bore and are install above the camshaft. Its tricky. You need a cam shaft lifter tray and have to wiggle in the lifters into position. I put in new lifters in my engine. I don't like flat camshafts. The fun starts when you drop a lifter into the oil pan and you have to go fishing. Some guys drop the oil pan and install the lifters with the engine upside down. Of course the motor has to be out. I think that F1 sells cams that don't need new lifters. My stock cam had a flat/worn lobe. If buy a new cam look for a cam with the 12v lift pump lobe on it. Some people like the bolt-on cam gear, instead of the pressed on gear.
Try a magnetic pickup tool and plenty of patience... it went down there - so it can come back up the same way!
Anybody know the exact lifter I.D. and depth? I'm not thrilled about a set of 1/2" wooden dowels rolling around in the Snap-On, so I want to machine a set from 6061 aluminum... but the cam tunnel trough will stay PVC for a while!
I agree that the wood ones seem a little...unsophisticated, but I think they actually work better then metal ones would. With the hard wood dowels, they actuall compress a bit, when they are forced into the lifter. Kind of a interference fit. With metal you wouldn't have that. Just a thought.
Paul
Paul
good piks on http://www.relentlessdiesel.com/.
cam install in the forum.
I would def use wood dowels over aluminum, wood can smush into a tight fit and can put a fresh new tapper grind after each use. I've never had an issue with 1/2" wooden dowls. Plus their cheap And If the stock cam looks ok I would just re use the stock lifters with a Helix Cam.
Brett
Brett
