which cam
which cam
well i have to tear down the motor completely and get the number 6 fixed so while im in there im going to put a cam in it but want everones opinion on which one to buy.
What kind of luck are you guys having with the reground cams holding up? I've heard horror storieds of them wiping out a lobe or something. I'd like to do a cam to mine eventually, but I want something that will be durable as well.
all of my trucks except 07 have maxspool cams, oil analysis reports have shown no excessive wear. and i reused tappets in my 1992, 15,000 and a oil analysis every oil change. besides the price is way less and you can get the bolt on gear and or a new custom blank call garrett shields at puredieselpower he knows alot about maxspool and greg hogue.
I like my Helix II but I think you would be pretty happy with most if not all of the bigger name cams. I doubt you would need a bolt on gear set-up unless you have no plans to go to a P-pump.
yes they are...but you can order new ones cut from a blank...but they are a LOT more $$
I am putting a Helix 2 in my truck....I have never seen any F1 cam failures but I have seen a few regrinds posted up with failures...I dont want to be taking my engine apart any more then I have to so I will pay for longevity.
