california emmisions
I am moving to Missouri this weekend. I bought my 97 a month ago, due to budget set forth by the ol lady, I havn't started bombing yet but plan too. My question relates to the emission equipment on my truck, and the effects of bombing. If I add products like exhaust, fuel plates, and injectors, will this effect my motor at all? Is there items that I will be able to remove that effects the power or smokability on my California emmisions truck? I am not worried about these items as there is no emmision test in MO. ;D
Re:california emmisions
I believe you truck has the EGR system that can be removed and it will help you out. as far as bombing the Calf. truck I think you will be fine.<br>DM01
Most,<br><br>I'm not 100% sure but I think you only have and EGR and a Cat. Also I believe the pump timing is a bit different. I'm sure you can bypass the EGR. Remove the cat as it's probably getting plugged anyway. If the truck has been in a snow belt area, you'll probably need a new exhaust. Check the rear of the muffler for signs of rust/holes. That's usually where they go bad first. Any good diesel shop should be able to set the timing for you.
Mostwanted take it over to Brandon's place and hecan show you what to do, pretty much just rip it out and start bombing 12 valve style ;D<br><br>Are you going to the pull in Stocton tommarow ?<br><br>BBD
He lives in Modesto, Exstream Diesel is one of his bissness call him at (209) 578-1850<br><br>You can meet alot of us at the Pull in Stockton, if your up to it, tomarrow at the Stocton 99 speedway.<br><br>BBD
wish i could have met yall sooner, but I am movin to Missouri monday. We are having our gon away party tommorow. What time are you meeting and how much to get in?
Yeah to bad we didn't hook up ealier, most of us hang out over at the TDR and Diesel central. There are plenty of Diesel heads in the central parts.<br><br>HERE is more info on the pull most of us will prolly start showing up about 10:00 and will be there all day.<br><br>BBD
That sux, my truck is at the body shop :'(. As a general rule: 12V has a cat. and 24V has a resonator. Exceptions are the change over years(early '94 & '98). Hog it out & let 'er flow.
justutt67
12-08-2008 05:49 PM
rentacop911
12-10-2007 11:10 AM
3Sigma
09-27-2006 12:35 AM
Palmetto_kid
01-18-2004 03:36 PM
Commatoze
12-17-2003 06:16 AM
