Cab lights how to replace bulbs
I think mine is all one piece, just hold the bottom of the bulb and twist it out of the housing. I havent done my cab lights for a year and really cant remember but hope this is right.
it is on a 96 truck I think the 94-97 are different. the power line to the light only has like a 1/4 inch in it and I can not get my fingers under the housing.
when u remove the two screws and lift up every thing to include the bulb and the lower portion of the light lifts up nothing stays attached to the truck. the only thing holding it to the truck is the power wire to the light
I replaced a cab light bulb on my truck yesterday. And all i did was pull on the light some and i had enough wire to easily get to everything. You sure the wire isn't just hanging up.
Yes there is nothing left on the truck. If you look on the under side of your light the bulb and wires should be sticking in at 45 degrees or so. You might be able to pull a little slack out and just twist the wires and bulb out all together, its very simple once you get one done. Unless somebody has put some aftermarket cab lights on this should be the way its done.
thanks for your help guys the power wire must just b stuck on something in the cab. I was able to sneak my little finger in their and get the cover loose
Scotty
02-27-2012 08:20 PM
Viperdew
01-02-2009 12:13 AM
rollerink
04-09-2008 08:47 PM
Thunderjet
11-13-2005 10:05 PM
NJMurvin
21
04-22-2005 08:38 PM
