Bypass on Holley Blue pump??????
For the guys running a Holley Blue pump, do you use a bypass with the pump?
Are you still running the stock lift pump?
Your help is greatly appreciated
I am running no bypass on mine thru the stock filter mounted LP, I have 22.5 psi @ idle but it will pull down to less than 5 with my mods (not enough). I am getting ready to do the Glacier system.
This is going on a 2000 cummins, with 275rv injectors, and a Comp box. Do you think this pump is enough? I think it should be, but just thought I would ask...
Registered
AlCorr
114
02-11-2009 02:32 AM
Texaschevelle
26
11-16-2007 08:08 PM
