Bully Dog Torque plate
I have a 97 4x4 with 252000. I recently had 4" pipes an AFE Breather and a stage 4 Bully Dog Torque Plate put on. It runs like a champ better than I ever expected and the milage is better but it really blows the black smoke. Way too much and is blackening my rear quarterpanel. Is there a way to back it off just a little?
what ypu can do is get into the injector pump where the plate goes and just remove the four screws to get to it, The screws hold down the AFC housing, remove the 4 screws and then you will see the torque plate. Once u see that torque plate loosen both screws and you can adjust the plate position, move it back towards the steering column. You can also even "fine adjust" the smoke. On top of the AFC housing you will see a hex screw, remove that and you can access the "starwheel" that is sort of the lower boost control and smoke control on the lower end of the torque spectrum. If you loosen it, you will have more smoke and lower end, if you tighten it, you will have just the inverse, no real performance gains can be expected from starwheel adjust...
Tx
davedye
11-03-2006 07:50 PM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
