bully dog torque plate
Old 02-24-2007 | 02:14 PM
b.white's Avatar
Got a steal on this stage 2 kit from bully dog but don't know a lot about the 12v fuel system and how to install it. i have a 94 auto
Old 02-24-2007 | 08:04 PM
Muddin_dude06's Avatar
If you look underneith the intake elbow right behind the lines comming out of the injection pump there is a small egg-shaped cover. That is your AFC, there are four bolts that hold it down, one being a "tamper-proof screw". You might have to use a chisel to get the tamper-proof out. Once you take that housing off you can see your Fuel Plate, there are two screws that hold it in place, take it out and replace it with the new one from your Bullydog kit. Adjust it as far as you want forward but make sure the Governor Arm hits the bottom edge of the plate and begins to ride up that surface nice and smooth. If you don't have gauges be very careful when doing this though as egt's can get hot awful fast!
Old 02-24-2007 | 09:22 PM
b.white's Avatar
thanks for the advice do you have any sugestions on whare to set it for daily driving but still need that power for towing and play....at what temp do the egts get dangeres what is my target temp to stay at
davedye
11-03-2006 08:50 PM
Woolybooger
11-14-2005 01:08 PM
chevkiller
16
02-16-2004 02:14 PM
Push Rod
02-08-2003 08:51 PM
