bully dog big fuel kit
so i just perchased a bully dog big fuel kit, is anyone running this pump if so please give me some feedback on how they like it. and also how hard is the install?
I have it on my truck now. I put it on about 10-11 months ago. Around that time I had my VP44 and the lift pump die. Dodge replaced the VP44 and installed the in tank pump. So I decided to add the Bully Dog kit to help boost my pressure. 2 weeks ago the intank pump died and I decided to install a Draw Staw II and totally bypass the intank pump all together. The only think you will need to buy is a relay for the Holley to run off of. Then you can use your trigger wire off of the relay to connect to the power wire on the lift pump. That way the truck will turn the pump on and off. The installation process is not that hard at all. Overall, I have been happy with the kit!!
CumminsRedneck
15
08-22-2006 04:11 PM
