Building a front weight bracket
Im tryn to get started on a front weight bracket for my truck. Livin on a farm i have access to a lot of different size suitcase weights, so thats what ill be using. I was jus trying to figure out the best way to make one, as well as how to get it to the frame. So any thoughts and ideas will help
thanks
mitchell
thanks
mitchell
what i did i took a one of them hitches with the square hole off the back of my truck when i got a dmi bumper. the frame rails on my truck get narrower in the front so i just cut i think it was 3 inches of driver side of the hitch welded it back together and braced it a lot. then after a few drilling holes in the frame bolted it right up. It worked out good this way i get most of the weight on the drivers side. then for the auctual rack it is just a old ball hitch that the ball part was cut off and a flat peice of steel welded to it. i will take some pictures of it sometime. i just use a ratchet strap to hold the IH suitcase weights on there.(but they dont move some pulls they require them to be secured) i can hang 800 lbs on it.
for the second gens they make front hitches. and EEP sells them as well.
I made a front 2" receiver hitch like ihpower. I used 1/8" wall 2.25" square tubing for the cross pieces and 3/8" plate that attached to the sides of the frame where the stock bumper bolts fasten. Then I made a 6x18x1/2" plate to mount the suitcase weights and welded that (with gussets) to a 2x2" square tubing. The weight carrier slid inside the front receiver and held 750-1000 lbs of weight.
brandon.
brandon.
Originally Posted by johndeere1259
how come yall want more weight ono the front end
LUKE-MM-PULLER
Competition / Pulls / OffRoad
07-13-2007 03:09 PM
