Which box do you like the best??
Originally posted by HOHN
I'm not going to upgrade to a Drag Comp, because I feel that they are all heat and no power on an HO truck. You just don't have enough pump for the Drag model.
Justin
Justin
I had an older, pre-China EZ stacked on my TST (non competition), for best of both worlds...with no problems....ever!
RJ
duke1n, if you give me a bit of notice, i'd be willing to send you my drag comp for a comparative test. with the MAD ECM i can run without the box, and i could probably live without it for a day or two (MAYBE!). if you have a dyno event or a dyno tuning session coming up give me a shout. maybe we could split shipping as long as you share the info. or someone could send e regular comp to me.
the only difference witht the drag version is the fueling over 2700rpm, and i haven't seen a dyno chart yet that has max power above 2800...
Thanks for that offer! I did notice all my peak HP #s on every run was at 2750 where I believe the ECM starts to defuel? I'm pretty tickled with the way it runs now making that kind of power at this altitude with the managable EGTs and boost. I'm almost afraid to mess with the box lol. Doug or any of you... are boxes coming from Edge consistent in the way the perform on the same truck? I know truck to truck can be different but on the same truck, is any Comp you get from Edge going to behave in the same manner? Thanks for all the help.
Doug, so meth acts a fuel source... at 50/50 what you expect to see in increased HP with my setup?
Beast, I will be in touch with you if I don't get a warm fuzzy that if I simply have my comp re-flashed, it will not produce very similar results. I know 5x5 fueling over 2750 will produce some additional heat... I just don't want it to be a bunch hotter on 3x5 than my std comp is now. Supposedly they only alter fueling past 2750 on 5x5 but I have heard rumors that they may be hotter on all settings than reg Comp. Can you shed any light on that Doug? Thx
the time it takes to go from 2700 to 3200 is dang quick! I have tried a bunch of times to see if any heat builds faster at higher rpms but only strapping it down will tell, on the road stuff is happening way too fast to look over and down
Brandon, that was what I wanting to see. Thanks
Stacking boxes... I know lots of people are doing that. Makes me wonder why Blue Chip didn't add timing to their fueling box? How about a full B1 and Mach6s with a drag comp lol. How much HP will a stock NV4500 take? What breaks first?
How about this:
Blue Chip Redline Box, stacked with an Edge Comp (no pump wire, but in cab adjustability), Mach 6 injectors, and a oversized B-1.......
Doug
Doug
Bounty Hunter
04-23-2008 08:00 AM
D45
04-09-2008 05:27 PM
04ctd
10-05-2006 08:27 PM
whatdieseltoget
11-06-2005 08:33 PM
600 Megawatts
11-01-2005 08:20 PM
