BOSCH 370 injector installation kit part#?
Old 02-26-2005 | 01:00 PM
northslope's Avatar
Anyone have the BOSCH part number for the 370 marine injector installation kit?
Old 02-26-2005 | 01:22 PM
northslope's Avatar
Oh and the BOSCH # on 191 delivery valves too
Old 02-26-2005 | 02:43 PM
perkins's Avatar
#0432131753 Is a new no. 0432131715 is the older no.
Old 02-26-2005 | 03:01 PM
northslope's Avatar
Those are the actual # for the 370 injectors, not the install kit or the 191 dv's, but thanks anyway!
Old 02-26-2005 | 08:20 PM
Rhino's Avatar
The install kit isn't necessarily a Bosch part. www.usdieselparts.com sells injector install kits for $10.50
Old 02-27-2005 | 02:10 AM
northslope's Avatar
Understood, but goal here is to get BOSCH p/n#'s on a 370 marine install kit and the BOSCH p/n#'s for 191 dv's. I know these things can be had all over the place for x amount of dollars that is not what I'm trying to achieve. Our 12 valver's fuel systems are BOSCH that means BOSCH does or did make those such parts meaning there are such BOSCH p/n#'s, that is what I seek BOSCH p/n#'s. I'm sure when someone out there ordered their 370 injectors and 191 dv's the blang things came with BOSCH p/n#'s on them which is what I seek BOSCH p/n#'s
Thanks for your time Gentlemen, any assistance would be appreciated
Old 02-27-2005 | 07:22 AM
Rhino's Avatar
FWIW - Piers injector install kits are not Bosch.
Old 02-27-2005 | 09:53 AM
RedRotors's Avatar
Bosch # for 191's delivery-v : 2 418 552 191
Marc/
Old 02-27-2005 | 12:19 PM
northslope's Avatar
Thank you kindly RedRotors!!!!!!!!!!!!!!!!!!!!!!!
Old 02-27-2005 | 12:21 PM
northslope's Avatar
Shall I reiterate we're beating a dead horse here!!
Old 02-27-2005 | 12:37 PM
got...DIESEL?'s Avatar
I'll check my price on those monday northslope, I already told you how deathly cheap the 370's are right?
Chris
Old 02-27-2005 | 12:49 PM
Rhino's Avatar
I do not understand your infatuation with finding a Bosch injector install kit but I do understand what you are looking for. Hence the reason in my post I threw the FWIW in there. I was merely pointing out that one person that seeems to be pretty highly regarded in the diesel performance industry (particularly with 12v's) does not feel the need to use an original Bosch install kit.
Old 02-27-2005 | 01:25 PM
northslope's Avatar
The only thing I'm interested in is BOSCH PART NUMBERS!! I am a BOSCH AUTOMOTIVE dealer. Not a marine, industrial, or hd Bosch distributor. Meaning I can get genuine BOSCH parts for almost anything automotive, but the only thing I can get for our 12 valvers is rebuilt stock replacement injectors. I'm trying to aquire these part numbers because I may have found a source to get them not at wholesale or jobber but jobber minus x percent. That is my infatuation with BOSCH PART NUMBERS!!! WHY SHOULD I BY AN INSTALL KIT for $10.50 WHEN I CAN GET THE GENUINE THING FOR $3.00! If you must know that is why I want the BOSCH #'s. ARE YOU NOW AT EASE BECAUSE YOU NOW KNOW WHY I'M SO INFATUATED WITH BOSCH #'S///
Old 02-27-2005 | 01:40 PM
northslope's Avatar
I appaulogize for any I may have offended
In the future when I'm looking for BOSCH #'s I will clearly state that I'm looking for GENUINE BOSCH PART NUMBERS and NOTHING ELSE
Old 02-27-2005 | 01:45 PM
Rhino's Avatar
One other thing I might mention is that the Bosch 370 Marine injector install kit may not come with the "preferred" washer thickness. I have no idea what thickness of washer comes under the 370 injecotrs in a Marine application but it may not be the thickness of washer that would provide the best results on our trucks. Just a thought. Best of luck in your search.
Quick Reply: BOSCH 370 injector installation kit part#?
