boost seems low
boost seems low
ive read a lot of threads about how to increase boost, but i just cant seem to figure out why. i have an edge ez with the adjustable boost elbow screwed all the way in. i havent pulled with it yet, but i cant seem to get over 20 psi. any help would be great
Originally Posted by bryceepoo
When I had an EZ I could get up near 34 lbs but I had a banks quickturbo kit. Without the ez though I only get low 20's.
Originally Posted by jlebrun
you were probably could only see 20's because the EZ has the boost fooler so you can go higher right? i dont know a lot about it but ive heard that stock your computer will only let your boost get to 22-23 max, but with the EZ, your boost can climb as high as you want
Originally Posted by graphitecumnz
With a properly working EZ you should be able to hit 28-30+psi. I could hit 32psi with just an EZ.
Update: OK, im not sure what to do now. i tried the vice grip trick just to see what would happen and my boost didnt change, is my wastegate stuck part way open or why can i not get more boost with the wastegate hose pinched shut???????
JThiessen
16
08-22-2009 02:46 PM
The_Head
11-27-2008 12:23 PM
beaver76
11-11-2007 11:24 AM
tanderson2002us
06-20-2006 04:21 PM
