boost question
Old 09-11-2004 | 10:33 AM
44-40's Avatar
boost question
Finally got my tuner back after being fixed. Also got some gauges. Will be getting boost fooler soon. I figure I need about 10 lbs more boost. Instead of using devices to somewhat restrict the waste gate why can't you just close the waste gate totally? What kind of boost would your turbo make then?
Old 09-11-2004 | 11:57 AM
The problem with just closing the wastegate is that you can overspeed the turbo and blow it up. You can run a boost elbow, either bought or home-made, or you can buy a Turbo-Master wastegate controller (adjustable with 1/2" wrench). The turbo only makes good boost up to 35 psi, after that it's just heating the air - which means you get less air rather than more.
goose2w1
07-23-2008 11:49 PM
3500_CTD
14
02-05-2008 09:33 AM
TorqueJunkie
15
08-30-2006 10:15 PM
RockcrawlingTJ
07-22-2006 06:11 PM
GTSDave
07-08-2005 10:06 AM
