boost pressure?
Old 12-04-2013 | 12:54 PM
mattn124's Avatar
boost pressure?
Hello,
I have been searching on here but ahven't found it yet.. What are the boost pressure numbers I can expect from a "stock" truck?
I ask because I am making a wish-list to hand the wife for Christmas, on that list is going to be boost/pyro gauges and a holder for my truck (see sig)
I have the factory turbo and manifolds (upgraded airbox and injectors though)
How high should the boost go? I am trying to decide between the 35 psi or 60 psi autometer gauges.
I have no plans to completely bomb the truck. Might get a Smarty someday though.
Thanks,
Matt
Old 12-04-2013 | 02:25 PM
CarlJensen's Avatar
Get the 60psi. Any gauge is the most accurate at mid range . If you make over 40psi you are taking a chance unless you have studs and a better head gasket.
Old 12-04-2013 | 03:28 PM
mattn124's Avatar
Thanks for the suggestion! I think I will go that route.
Just for my information though, what are the boost pressure readings that would be considered "normal" for a stock-turbo truck?
Old 12-04-2013 | 04:53 PM
BarryG's Avatar
on my 01 auto with the hy turbo iirc max stock boost was 20 as that was how the wastegate and ECM were set. Wastegate would open by 20 and if the ecm saw above 20 it would defuel. Even after I put on an edge ez which had a boost fooler in it which took care of the defueling aspect it still wouldn't go above 20 until I turnbuckled the wastegate.
Old 12-05-2013 | 04:21 PM
CarlJensen's Avatar
The waste gate limits high boost to whatever it is set at. My waste gate has been blocked off for years. I won't go above 40psi as I don't have studs in the head. The waste gate on mine is adjustable, even if not in use.
Old 12-06-2013 | 01:49 PM
infidel's Avatar
Good reading http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Old 12-11-2013 | 08:38 PM
Originally Posted by infidel
That is good reading.
Cool info on the factory waste gate PSI settings and housing sizes for each model/year
Thanks Bill!
Old 12-29-2013 | 08:32 AM
klcammie's Avatar
I agree good read. lots of info to consume. Thanks for the link!!!!!!!!!!!!!!!!!!!!!
Old 02-21-2014 | 12:44 PM
mattn124's Avatar
Thanks all for the replies!
Well, I am going to try and install this gauge and an EGT gauge in the next couple weekends or so.
Any recommendations for how to hook-up the Boost gauge? I hear about a "Boost-Bolt".. Is that the easiest/best way to get boost pressure to the gauge?
Old 02-21-2014 | 01:03 PM
Sea:\>Drive's Avatar
Driver's side of the engine by the map sensor (way in the back - map has a grey plug and wires hanging off it) is a manifold plug - take it out - go to hardware store and find a brass plug with a nipple same size - put it in, run your hose to your gauge - done!
Old 02-21-2014 | 10:07 PM
BarryG's Avatar
Boost bolt may be the easiest but not the cheapest. As sea drive mentioned there is a plug that you can take out and replace with the proper size bushing for a few bucks. Careful not to pull the wrong plug there is another one there that is a coolant galley plug
Old 02-21-2014 | 11:14 PM
SIXSLUG's Avatar
Good reading, indeed. Thanks, Infidel!
HOHN
45
10-08-2005 09:51 AM
triplenickel
08-23-2005 05:01 PM
GTSDave
07-08-2005 10:06 AM
MY WORLD
25
12-29-2004 09:54 PM
Palmetto_kid
01-16-2004 03:21 PM
