boost in overdrive?
boost in overdrive?
I pulled a 12000 lb trailer last weekend. In drive I could see 35+lbs of boost. In O.D. I could only get 21lbs of boost, even when I had it almost to the floor. (just before it would down shift) Without the trailer I can get 35+lbs of boost in O.D. Does this make sense? Am I running out of fuel? Thanks.
Could you have been slipping the convertor? Boost is a product of engine load and fueling. You can have a boost leak, but that should happen under all conditions. I don't know enough about 24V to help you much.
How do I get around this. Maybe i'm dreaming but, I would like my truck to pull a trailer like my dads 12v. In overdrive he can get 40+lbs easy. I was thinking it is my stock injectors. And I'm sure the converter isnt slipping. It was staying around 1600-1700 rpm.
72demon440
04-27-2007 11:45 PM
triplenickel
08-23-2005 05:01 PM
GTSDave
07-08-2005 10:06 AM
Palmetto_kid
01-16-2004 03:21 PM
