boost numbers
Old 05-27-2007 | 07:26 PM
bigmack2500's Avatar
boost numbers
I just installed HTT Killer B2 64/14, I was just curious on what the max boost pressure is on this type of turbo? I'm only seeing around 30 psi max on stock sticks, and vp. If I upgrade those items is it possible that I could see more PSI.
Old 05-28-2007 | 11:17 PM
displacedtexan's Avatar
Bump.
You would definitely see more boost with bigger sticks.
Old 05-29-2007 | 12:45 AM
Ph4tty's Avatar
30 is a good psi for that turbo- its very effecient at that level. I've run mine to 47 several times and it should be able to handle a couple more psi than that.
Old 05-29-2007 | 03:23 PM
RowJ's Avatar
More Fuel = More boost!
That turbo is within it's 'Map' up to 40 psi.
Lot's of room to grow.
RJ
Old 05-29-2007 | 05:11 PM
thanks for the info, I'm waiting to get my tranny done before anymore mods occur. Then it ***** to the wall, stage 5 jammers, HRVP, Fass LP
Old 05-29-2007 | 11:50 PM
Ph4tty's Avatar
RJ
And you've seen the map?? Even at 45-47 temps don't rise very quickly ime so I always figured that was the top end of the map. II did tell me that a 64/14 is most effecient around 32 so you might be right Rowland.
sCreamin400
11-02-2008 02:46 PM
sammy340
01-14-2005 02:04 AM
CTD2001
16
11-22-2004 02:43 AM
canucktrucks
11-12-2004 08:37 PM
hellotbone
15
03-31-2003 07:49 AM
