boost gauge sender
boost gauge sender
I know I could probably do a search and come up with 42 pages to read but...
Any way, on a 98 24 valve, where are you guys tapping in for a boost gauge reading. It looks like the air horn could be drilled and tapped without too much trouble. Is that a good place to get a true reading?
Thanks,
Steve.
Thanks,
Steve.
On the 24 Valve the boost pressure port is a 3/4'' pipe plug requiring a 1/2'' square drive ratchet extension for removal and is located on the side of the intake plenum rearward of the fuel filter bracket. You'll need a bushing to reduce it to 1/8'' for your gauge line.
Copenhagenjunkie
04-05-2005 04:59 PM
