Boost gauge rattles
Old 05-01-2008 | 06:24 PM
mattpatt's Avatar
Boost gauge rattles
i just put in pyro and boost gauges about three weeks ago and the last couple of days i've noticed the boost gauge rattle when i'm excellerating. i've checked all of the connections and there good. has anyone else had this happen? if so how did you fix it? thanks
Old 05-01-2008 | 06:51 PM
moparmikej's Avatar
My Isspro boost gauge rattles also at about 20 and above lbs. Don't know why. I'm living with it, though.
Mike
Old 05-01-2008 | 11:12 PM
mattpatt's Avatar
yeah thats about what i was going to do unless someone had answers. thanks though.
Old 05-02-2008 | 12:06 AM
hink's Avatar
http://www.dieselmanor.com/dm_products/fittings.asp It's the one called a Pressure Guage Stabilizer, also known as a "snubber". I had to put one on my boost gauge too.
Old 05-02-2008 | 12:16 AM
Lil Dog's Avatar
There is a small orifice in the Isspro gauges that sometimes comes loose. If you pull the fitting off of the gauge you should see a small slotted orifice threaded into the gauge port. Might be loose. I have to look at mine soon, got this tip from another DTR dude.
Old 05-02-2008 | 11:21 AM
Lil Dog's Avatar
Wow, thanks Michael! I will check it out.
popeyesides
05-19-2006 11:10 AM
silverram323
01-05-2004 12:23 PM
jd knite
04-03-2003 03:07 PM
Dieseldude4x4
12-27-2002 02:44 AM
