Boost Gauge Installation
Old 09-30-2012, 11:04 AM
DTR's Cow Boss
DodgeCowboy's Avatar
So finally getting around to installing my boost gauge,couple of questions...
So I got the 1/8npt boost bolt,does it matter with 10mm bolt I take out of the intake horn? I have been told to use the ones closet to the valve cover.
Since there is only one power wire going to this gauge for the lighting and I would like to have it dim with the dimmer like my pyro gauge...So with that is the light on the gauge enough of a draw that I should not just tap in the the pyro lighting wire? or should I just run it off to the ash tray as to not have all the load on the dimmer switch?
Old 10-09-2012, 02:34 PM
nkennedy's Avatar
I went with the closest bolt, and taped the cig. light to get the dimmer function.
Old 10-09-2012, 05:58 PM
DTR's Cow Boss
I ended up using a fuse tap and piggy backed off the illumination fuse to get the dimmer to work. I did not want to splice the wire again as thats what I did when I installed the pyro.
Old 10-09-2012, 06:41 PM
infidel's Avatar
You'll be fine tapping into the same dimmer wire as your pyro.
Old 10-12-2012, 09:32 AM
DTR's Cow Boss
Done and did,was easier than trying to reinvent the wheel and add a bunch more wires to the pillar. My next quest is to find a better dual pod a pillar setup I hate the over lays with a passion.
6.7 Inside
01-04-2008 12:27 AM
Firstgenfanatic
09-18-2007 05:25 PM
MPowell800
08-18-2004 07:09 PM
KC
07-06-2003 04:22 PM
Redleg
03-20-2003 04:35 PM
Quick Reply: Boost Gauge Installation
