boost gauge install
Originally Posted by AggiePhil
Where are you guys finding this "Boost Bolt" on the Geno's site? I don't see it under the Gauge Fittings subcategory. Also, does the tubing necessary to do this kind of installation come with the ISSPRO gauges, or do you have to buy it separate (if separate, what kind of tubing should one use)?
Yes the tubing (10') and connectors (both 1/8" and 1/4" pipe fittings) are included, at least from Geno's, don't know about everyone else.
Not trying to hijack, but had a similar question. The guage I have does not include the tubing/adapters/etc... Any suggestions on what to get and where to get it (tubing, etc...). My directions say use flexible rubber hose, but I don't think vacuum tubing will hold upwards of 30lbs of boost, or will it?
http://www.dieselmanor.com/ will have everything you need. Or you can get a kit from Autozone and some bushings from the hardware store (or the tap you'll need- either way)
Tank_66
02-28-2008 08:34 PM
