Boost gauge install
Boost gauge install
Just got a set of Phantom boost and pyro gauges. Im going to put the pyro probe in the exhaust manifold but i haven't decided what to do with the boost tube. Should I just take the intake horn off and drill and tap a whole in it. Or is there a pre-drilled and plugged whole in the intake manifold that I can use. Thanks, coop
I tried to find my link for it but couldn't find it. Do a search here and you'll find a buttload of useful info. There is an unused port on the backside of the head near the fuel filter that you need to buy a couple of adapters for. There's no need to drill and tap if you don't want to.
Pyrometer probe fitting
Great. I ordered the boost bolt replacement. Also, i just noticed that the pyrometer I received does not have any kind of fitting on the probe. (i bought it used I guess he kept it). I tried to attatch a picture but I dont know if it worked or not. Anyways Does anyone know where I need to order the compression fitting from. The gauge is an autometer phantom series but I cant find anything on their website. So if any of yall have any idea where to get this part it would be appreciated. Thanks
Tank_66
02-28-2008 09:34 PM
