Boost fooler for a '95?
s there a ready made boost fooler for a '95? Would it just restrict the boost to the wastegate and make it stay closed longer?
Can I just "create" one? I have some small drill bits, if it is just a small orifice in the wastegate boost line.
What say you all?
What say you all?
Re:Boost fooler for a '95?
Take the boost line off of the AFC housing and block it completle off and there you go all the boost you could want unless you take the 3/8 alle out on top of the AFC and spin the turn dial till it is all the way loosened up (towards the front of engine)and your done go buy some 370s and take the fuel plate out and put it in the glove box and go have some SMOKING fun!!!!!!!!!!!!!!!!!
If you're going to increase the boost, you need to increase the fuel to go with it if you intend to get more power. Best way is with TST kit which gives you the fuel plate and the boost elbow.
Whichever you do, you need guages first to monitor EGTs and boost pressure.
Bill
Bill
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
