Boost Fooler?
Boost Fooler?
So is this correct... the BD boost "builder" is a boost fooler, fueling for more boost, and does it trick the computer to allow over 20psi or just fuel to get to 20psi faster? If so, does it go well with the new wastegate or is it worth just waiting to do a turbo? By the way I will be putting an edge comp on in a few days (fuel and timing only right?) Well there's a lot of questions, BD's site isn't very helpful.
I see now, unless it's getting too hot, I don't need the fooler, but a new wastegate or boost elbow will raise the pressure and help give some power (if there's more fuel to burn right?)
Edge comp has a boost fooler built in.
The BD Boost Fooler is only an electronic gadget that fools the ECM into thinking it's not at max boost, unless you do something to the turbo wastegate it will still open up at 19-20 psi regardless of what the ECM thinks.
phox
phox
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
