Boost Elbow vs. Wastegate
Old 05-22-2007 | 10:29 PM
dieselfuelonly's Avatar
DTR question asker
Sorry if this is a stupid question, I'm just trying to figure out what the difference is and a search didn't turn up much. From what I understand the boost elbow lets you set an "air leak", sort of like adjusting the waste gate (I think its adjustable, corect?). Is the boost elbow more of a fine-tune adjustment? Thanks!
DFO
Old 05-22-2007 | 11:24 PM
J Lent's Avatar
Yes the wastegates are adjustable....basically you are setting the system to open at a given pressure. The adjustable boost elbow is basically like holding your hand over your mouth & trying to exhale.....the bolt screws in & blocks the pressure from releasing. I'm not real sure if this helps, but I tried.
Old 05-23-2007 | 02:08 AM
Ph4tty's Avatar
The boost elbow slows the rate air reaches the wastegate thus allowing you to run more boost than the wastegate would normally allow. I haven't played with wastegates yet, but I think you just lengthen/shorten the rod to adjust where the wastegate opens.
Another option is a manual boost controller which would allow for easy boost adjustment without bleeding air off like the elbows do
dodgediesel
14
12-14-2006 10:54 AM
claw1
11-01-2006 12:49 PM
GlennRMK
03-02-2006 03:27 PM
G-NOTE
08-31-2005 08:48 PM
Lrdchaos
08-30-2005 07:45 PM
