Boost Elbow ???'s
You actually need a boost elbow and a boost fooler. Many boxes (such as the Edge EZ and Comp, the DD TTPM and UFM) have the boost fooler function built into them.
Rusty
Rusty
The boost elbow is the little brass elbow on the side of your turbo that is connected to the waste gate. The one everyone is talking about has a small hole in it to bleed off air pressure. This allows the boost to go higher before opening the waste gate. You will still need a boost fooler like what is in the Edge and other products as listed above to keep from defueling and setting codes.
On my truck, the various boost pressures and pre-turbo EGTs are as follows:
Stock - 22 PSIG, 1300 degF EGT
EZ (with boost elbow), 4" exhaust - 30 PSIG, 1100 degF EGT
EZ (with boost elbow), 4" exhaust, DD2 injectors - 34 PSIG, 1225 degF EGT
Rusty
Rusty
Could be a lot of things. Boost leaks. Internally fouled intercooler. Dirty air filter. Poor turbo efficiency. Cracked exhaust manifold or exhaust manifold leaks. Wastegate or wastegate actuator/piping leaking. You may just need more fuel to make more boost. It's hard to say without diagnosing the truck firsthand.
Rusty
Rusty
i can't really see why anyone uses a boost elbow. i just plug them off and if it starts putting out better than 40 psi i put on a bigger exhaust housing.
i would suggest you tighten down the allen screw all the way in your boost elbow first.
Cumminsdude
It sounds like you might have something wrong. I can spool up to 25 psi without trying hard. What setting is your EZ on?
Have you checked you lift pump pressure? If it’s real low at WOT then you’re not getting enough fuel to the VP44. You need more power to spool up that turbo.
It might be a good idea to check all the boots as mentioned above. You will have to put a wrench on them because they can look tight but be loose enough to leak under pressure. If this is the problem you will most likely be seeing high EGTs.
Hope this helps.
Hope this helps.
Alright, I'll go check all those and tighten them and look for leaks. I STILL havent gotten my Fuel pressure guage hooked up yet so I cant tell you what that is but I am planning on buying a LP soon. As far as the ez settings go, I can't remember what setting it is on but what setting do I want it on for the most power and most smoke? All the way to the left or all the way to the right? Thanks
2. Yep, a bad lift pump might be starving the VP-44 for fuel under maximum load - in addition to risking the VP-44, that could starve the turbo for drive energy. I believe one of the TSB symptoms is stumbling or loss of power complaints under heavy loads - like towing up a hill.
3. With the end cover off and the Edge Products logo on top, position #3 (earliest fueling) will have the jumper at the far right. If you haven't changed it, that's where it should be - they ship them with a default setting of position #3.
Rusty
dodgediesel
14
12-14-2006 09:54 AM
TorqueJunkie
15
08-30-2006 09:15 PM
RockcrawlingTJ
07-22-2006 05:11 PM
triplenickel
08-23-2005 04:01 PM
Palmetto_kid
01-16-2004 02:21 PM
